I have followed the available posts as much as possible to configure NFS on two Ubuntu machines.
I have installed the nfs-kernel-server on the host system, set up the exports on the server. I even shut down the firewall to make sure it wasn't getting in the way. The client machine also has the server installed as well as the nfs-common client package.
When I attempt to mount ANY of the shares at the client. (current mount location is /home/nfs_local). The terminal hangs with no response for a very long time, when it just says "Connection Timed Out".
I am trying to mount using this command structure to mount the shares at the client's terminal:
$ sudo mount 192.168.10.111:/home/uname /home/nfs_local
Here is what my exports currently look like in /etc/exports
/home 192.168.10.128/255.255.255.0(ro,anonuid=65534,no_subtree_check,insecure,sync,nohide) /home/uname 192.168.10.128/255.255.255.0(rw,anonuid=65534,no_subtree_check,insecure,sync,nohide) /mnt/volumes/Massive_A 192.168.10.128/255.255.255.0(rw,nohide,no_subtree_check,insecure,sync) /mnt/volumes/Massive_B 192.168.10.128/255.255.255.0(rw,nohide,no_subtree_check,insecure,sync) /mnt/volumes/Massive_C 192.168.10.128/255.255.255.0(rw,nohide,no_subtree_check,insecure,sync) /mnt/volumes/SSD_B 192.168.10.128/255.255.255.0(rw,nohide,no_subtree_check,insecure,sync)
rpcinfo -p (server side) gives the following output:
100000 4 tcp 111 portmapper
100000 3 tcp 111 portmapper
100000 2 tcp 111 portmapper
100000 4 udp 111 portmapper
100000 3 udp 111 portmapper
100000 2 udp 111 portmapper
100005 1 udp 46285 mountd
100005 1 tcp 40996 mountd
100005 2 udp 37056 mountd
100005 2 tcp 56903 mountd
100005 3 udp 59774 mountd
100005 3 tcp 33079 mountd
100003 2 tcp 2049 nfs
100003 3 tcp 2049 nfs
100003 4 tcp 2049 nfs
100227 2 tcp 2049
100227 3 tcp 2049
100003 2 udp 2049 nfs
100003 3 udp 2049 nfs
100003 4 udp 2049 nfs
100227 2 udp 2049
100227 3 udp 2049
And, the firewall is inactive:
$ ufw status (server side and client side)
Status: Inactive
Can anyone spot what I am missing here? Eventually, I want to add these to fstab to be mounted automatically on boot... OR use a script for each share... Advice on the pros/cons of this usage also greatly appreciated.
Thank you for reading.
