I'm trying to create a Live USB stick with additional files on it. I created my live USB using Startup Disc Creator and I've tried to remount /cdrom directory as it described here but it answers
mount: cannot remount rw read-write, is write-protected
I even tried to write to the stick while I'm booted from my hdd, but with the same result:
fgh@fgh-box:/media/fgh$ sudo mount -o remount, rw /media/fgh/Ubuntu\ 16.04.1\ LTS\ amd64/
I also tried
sudo hdparm -r0 /dev/sdc
doesn't work.
I would be grateful if you help me with making it writable.
If you use mkusb to build your stick, it will create a persistent partition with the size you specify and use the remaining space for a NTFS partition that can be used by Linux and Windows.
C.S.Cameron
  • 20,530
  • 78
  • 125
