I've been trying to find a solution for a problem I've been having with my laptop on 16.04 LTS for a few days now. I can only get the wifi to work after coming out of standby by typing these 2 lines which,as far as I know,reloads the driver for the wifi pcb:
modprobe -rf rt73usb
modprobe -v rt73usb
I've tried a few methods to try and get this to happen automatically.One was from this thread which gave me this:
!/bin/bash
case "$1" in
thaw|resume)
sudo modprobe -rf rt73usb
sudo modprobe -v rt73usb
esac
exit $
I put this in a file called wakenet, details:
ls -al
drwxr-xr-x 2 root root 4096 nov 27 16:48 .
drwxr-xr-x 5 root root 4096 ago 5 2015 ..
-rwxr-xr-x 1 root root 210 giu 26 2015 10_grub-common
-rwxr-xr-x 1 root root 660 dic 6 2013 10_unattended-upgrades-hibernate
-rwxr-xr-x 1 root root 1260 mag 23 2012 novatel_3g_suspend
-rwxr-xr-x 1 root root 112 nov 27 16:48 wakenet.sh
Please could someone tell me where I'm going wrong because when coming out of standby I still get the same problem? I've only got the basics of what's happening so if you could help I would greatly appreciate it.I guess I've made a fundamental error with the script?Cheers.Mark
ps some more info:
lshw -c network
*-usb DISABLED
description: Wireless interface
product: 802.11 bg WLAN
vendor: Ralink
physical id: 3
bus info: usb@1:3
logical name: wlx0019db03e22d
version: 0.01
serial: 00:19:db:03:e2:2d
capabilities: usb-2.00 ethernet physical wireless
configuration: broadcast=yes driver=rt73usb driverversion=4.4.0-47-generic firmware=1.7 link=no maxpower=300mA multicast=yes speed=480Mbit/s wireless=IEEE 802.11bg
*-network
description: Ethernet interface
product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 5
bus info: pci@0000:06:05.0
logical name: eth0
version: 10
serial: 00:03:0d:5b:75:87
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=32 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
resources: irq:16 ioport:2000(size=256) memory:b0200000-b02000ff
output of lsusb:
Bus 001 Device 002: ID 0db0:6877 Micro Star International RT2573
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
