I have a dell Inspiron 15R 5521 with radeon 8730M / intel 4000 dual gpu configuration running Ubuntu 16.04 running kernel 4.8.1.I have been facing horrible screen tearing when using my discrete GPU using the DRI_PRIME=1 command.
I tried the solution given in this link here. However when is create this config file, I get a black screen on bootup or whenever lightDM restarts with the error
radeon vce init error(-110)
I remove that file the system back to boot without error, however is there any other solution to handle screen tearing while using my radeon gpu?
--EDIT-- i added the output of the file generated by the code
Ubuntu 16.04.1 LTS
Inspiron 5521
*-display UNCLAIMED
description: VGA compatible controller
product: Mars [Radeon HD 8730M]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller cap_list
configuration: latency=0
resources: memory:a0000000-afffffff memory:c0000000-c003ffff ioport:3000(size=256) memory:c0040000-c005ffff
*-display UNCLAIMED
product: 3rd Gen Core processor Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list
resources: memory:c1000000-c13fffff memory:b0000000-bfffffff ioport:4000(size=64) memory:c0000-dffff
as for the xorg.conf it gave the output cat: /etc/X11/xorg.conf : No such file or directory is that normal ?
-----EDIT-2----
So i tried to set up xorg.conf in an attempt to fix the issue using X -configure but i get the following error
Number of created screens does not match number of detected devices.
on googling the issue i found a lot of solutions that applied to different cases like dual monitor setups and all but none that fit my case.
here is the full log file describing my issue. Really appreciate if somebody could help me with this
