I installed Ubuntu 16.04 on my HP Proliant Gen8 but now I can only select 1280x1024 display resolution - but when I used the Live-System I could select more of them.
So I guess there is a problem with the display driver but I could not find the issue.
In Xorg.0.log I found "Failed to load module "mga" (module does not exist, 0)" but I have no idea how to fix this.
xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1280 x 1024, current 1280 x 1024, maximum 1280 x 1024
default connected 1280x1024+0+0 0mm x 0mm
1280x1024 77.00*
lspci | grep VGA
01:00.1 VGA compatible controller: Matrox Electronics Systems Ltd. MGA G200EH
lshw -C video
*-display UNCLAIMED
description: VGA compatible controller
product: MGA G200EH
vendor: Matrox Electronics Systems Ltd.
physical id: 0.1
bus info: pci@0000:01:00.1
version: 00
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list
configuration: latency=0
resources: memory:f9000000-f9ffffff memory:fbee0000-fbee3fff memory:fb000000-fb7fffff
