My apt is will not let me interact with a single package, account-plugin-google. Here is the output when I try sudo apt-get -f install
dylan@dylanredfield:~$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
5 not fully installed or removed.
Need to get 0 B/3,372 B of archives.
After this operation, 30.7 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
dpkg: warning: files list file for package 'account-plugin-ubuntuone' missing; assuming package has no files currently installed
dpkg: warning: files list file for package 'account-plugin-tools' missing; assuming package has no files currently installed
dpkg: warning: files list file for package 'account-plugin-flickr' missing; assuming package has no files currently installed
(Reading database ... 283341 files and directories currently installed.)
Preparing to unpack .../account-plugin-google_0.13+16.10.20160929.1-0ubuntu1_all.deb ...
Unpacking account-plugin-google (0.13+16.10.20160929.1-0ubuntu1) ...
dpkg: error processing archive /var/cache/apt/archives/account-plugin-google_0.13+16.10.20160929.1-0ubuntu1_all.deb (--unpack):
trying to overwrite '/etc/signon-ui/webkit-options.d/accounts.google.com.conf', which is also in package kaccounts-providers 4:16.04.3-0ubuntu1
I have been scrounging google for the last today doings a lot to try to fix the issue, but nothing has worked. Should I just call it quits and reinstall?
