I recently switched from 16.04 to Gnome version and I wanna roll back, is it possible?
Asked
Active
Viewed 167 times
Try this:
Start in text-only mode
- Switch on your computer. Wait until the BIOS has finished loading, and press and hold Shift, which will bring up the Grub menu.
- Select the line which starts with
Advanced options. - Select the line ending with
(recovery mode) - Press Return and your machine will begin the boot process.
- After a few moments, your PC should display a menu with a number of options, including
Drop to root shell prompt. Press Return with this option highlighted. - The PC will start in a terminal.
Run these commands:
Mount partitions in read-write mode
mount -o remount,rw /
mount --all
Update repositories
apt-get update
Install aptitude and deborphan
apt-get install --reinstall aptitude deborphan
Eliminate the components of gnome that are not necessary in Ubuntu
aptitude remove '?and(?reverse-depends(gnome),?not(?reverse-depends(?exact-name(ubuntu-desktop))))'
Reinstall ubuntu-desktop
apt-get install --reinstall ubuntu-desktop
Eliminate orphan packages
deborphan
apt-get --purge remove $(deborphan)
deborphan --libdevel
apt-get --purge remove $(deborphan --libdevel)
deborphan --find-config
dpkg --purge $(deborphan --find-config)
Remove unnecessary packages
apt-get autoremove
Remove downloaded packages
apt-get clean
Restart system
reboot
