I tried to download Skype and the latest version it said was Ubuntu 12.04 so I downloaded that. It opened in a Software Center with an install button. I clicked the install button and it went to 10% and just reverted back to an install button. I found this question but it gave an error:
chloe@chloe-latitude-d430:~/Downloads$ sudo dpkg -i skype-ubuntu-precise_4.3.0.37-1_i386.deb
[sudo] password for chloe:
Selecting previously unselected package skype:i386.
(Reading database ... 207595 files and directories currently installed.)
Preparing to unpack skype-ubuntu-precise_4.3.0.37-1_i386.deb ...
Unpacking skype:i386 (4.3.0.37-1) ...
dpkg: dependency problems prevent configuration of skype:i386:
 skype:i386 depends on libqt4-dbus (>= 4:4.5.3).
dpkg: error processing package skype:i386 (--install):
 dependency problems - leaving unconfigured
Processing triggers for hicolor-icon-theme (0.15-0ubuntu1) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160824-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) ...
 skype:i386
I found this answer but it gave an error:
chloe@chloe-latitude-d430:~/Downloads$ sudo apt-get install gdebi
You might want to run 'apt-get -f install' to correct these:
 gdebi : Depends: gdebi-core (= 0.9.5.7ubuntu1) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I also tried the 2nd suggestion:
chloe@chloe-latitude-d430:~/Downloads$ sudo apt install skype
skype:i386 is already the newest version (4.3.0.37-1).
 skype:i386 : Depends: libqt4-dbus:i386 (>= 4:4.5.3) but it is not going to be installed
I saw this answer, but after I added 'Canonical Partners' in Software & Updates, I searched for Skype in Ubuntu Software and it didn't come up. Only 'spreedme' came up.
Chloe
  • 153
To install Skype in Ubuntu 16.04, run these commands in terminal one by one:
sudo add-apt-repository "deb http://archive.canonical.com/ $(lsb_release -sc) partner"
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install skype
NOTE: sudo dpkg --add-architecture i386 is only for 64-bit system and not for 32-bit system. Also, if you get an error of missing dependencies, run sudo apt-get -f install from terminal.
Open Skype from Unity Dash. Then agree to Skype terms of use and Skype privacy policy. Next, sign in with your Microsoft account or Skype name. Then you're ready to use Skype!
Helpful Links
How to install Skype on Ubuntu 16.04 LTS
wjandrea
  • 14,504
