Whenever I add a repository using the add-apt-repository command, a Traceback is called regarding the files /usr/bin/lsb_release and /usr/lib/python3/dist-packages/lsb_release.py
(I'm using Ubuntu 16.04.1)
The output is the following when adding a repository:
Traceback (most recent call last):
  File "/usr/bin/lsb_release", line 98, in <module>
    main()
  File "/usr/bin/lsb_release", line 62, in main
    distinfo = lsb_release.get_distro_information(options.upstream)
  File "/usr/lib/python3/dist-packages/lsb_release.py", line 344, in get_distro_information
    distinfo = guess_debian_release()
  File "/usr/lib/python3/dist-packages/lsb_release.py", line 239, in guess_debian_release
    get_distro_info(distinfo['ID'])
  File "/usr/lib/python3/dist-packages/lsb_release.py", line 41, in get_distro_info
    RELEASES_ORDER.sort(key=lambda n: float(n[0]))
  File "/usr/lib/python3/dist-packages/lsb_release.py", line 41, in <lambda>
ValueError: could not convert string to float: '6.06 LTS'
    main()
ValueError: could not convert string to float: '12.04 LTS'
    main()
When I remove /usr/bin/lsb_release, I don't get that traceback, but in my system tray a red icon is shown to inform me that there's been an error getting the updates.
Thank you in advance.
edwinksl
  • 24,109
Mason
  • 361
