I can login to my Ubuntu 16.04 server no problem with my usual password but when I try to give admin privleges through terminal sudo -s, the password doesn't work. Strange because it always worked. I get the following error:
"Username is not in the sudoers file etc ...."
I did a search and it seems like a common error and recommend that go into recovery mode from grub.
http://www.tecmint.com/fix-user-is-not-in-the-sudoers-file-the-incident-will-be-reported-ubuntu/
But then there is no Recovery Menu that shows up (DOS window) from the grub recovery mode.
Help please!
If the problem is [only] with the sudoers file, you can find help at this Ubuntu help page,
help.ubuntu.com/community/Sudoers
The problem might also be with the /etc/group file, and in that case you can refer to the following link to another question here at AskUbuntu,
How do I add a user to the “sudo” group?
sudodus
  • 47,684
