I get this strange error trying to mount UFS partition.
sudo mount -r -t ufs -o ufstype=ufs2 /dev/sdb2 /home/tim/ufs_mount
mount: wrong fs type, bad option, bad superblock on /dev/sdb2,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
I'm a Ubuntu newbie and just switched from FreeNAS.
tim@T3:~$ sudo fdisk -l
Disk /dev/sda: 400.1 GB, 400088457216 bytes
255 heads, 63 sectors/track, 48641 cylinders, total 781422768 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000a77a6
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 765700095 382849024 83 Linux
/dev/sda2 765702142 781422591 7860225 5 Extended
/dev/sda5 765702144 781422591 7860224 82 Linux swap / Solaris
Disk /dev/sdb: 1500.3 GB, 1500301910016 bytes
255 heads, 63 sectors/track, 182401 cylinders, total 2930277168 sectors
Disk identifier: 0x90909090
/dev/sdb1 * 63 240974 120456 a5 FreeBSD
/dev/sdb2 240975 2928601304 1464180165 a5 FreeBSD
/dev/sdb3 2928601305 2930272064 835380 a5 FreeBSD
