12
I have mad a custom ini files in /etc/php/7.0/mods-available. how can I enable it. I have tried php5enmod, and php7enmod. none worked for me.
Thank you.
You can simply use the command phpenmod.
If you have several php versions intalled you can also use this syntax:
phpenmod -v 5.6 <modulename>
phpenmod -v 7.1 <modulename>
That worked in my case because I have 7.0, 7.1, 7.2 and 7.3 installed, but because of requirements I have to run my apache2 with 7.2.
  • phpenmod moduleName enables a module to php7 (restart apache after that sudo service apache2 restart)
  • phpdismod moduleName disables a module to php7 (restart apache after that sudo service apache2 restart)
  • php -m lists the loaded modules
  • To check available modules, run php -m - it's a content of /etc/php/yourPHPVersion/mods-available
  • Select module from the list and enable it (let's say you want to enable soap) phpenmod soap
  • Reload apache2 service apache2 reload or systemctl reload apache2 And you have a module enabled.
  • To disable the same module, run phpdismod soap, reload apache2 service apache2 reload
atom_n
  • 36
