Ubuntu installed some updates, and after the restart, I cannot log in. It seems to accept, but then beeps and returns to the login screen. All of the users, including guest do the same thing.
I was looking at some other posts here, and tried some of the suggestions without success. I looked at the .xsession-errors file but I don't understand the error:
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  155 (GLX)
  Minor opcode of failed request:  3 (X_GLXCreateContext)
  Value in failed request:  0x0
  Serial number of failed request:  34
  Current serial number in output stream:  35
openConnection: connect: No such file or directory
cannot connect to brltty at :0
upstart: gnome-session (Unity) main process (1751) terminated with status 1
upstart: unity-settings-daemon main process (1737) killed by TERM signal
upstart: Disconnected from notified D-Bus bus
upstart: logrotate main process (1601) killed by TERM signal
upstart: update-notifier-crash (/var/crash/_usr_bin_compiz.1001.crash) main process (1669) killed by TERM signal
upstart: update-notifier-crash (/var/crash/_usr_bin_compiz.1002.crash) main process (1671) killed by TERM signal
upstart: bamfdaemon main process (1730) killed by TERM signal
upstart: hud main process (1735) killed by TERM signal
upstart: indicator-bluetooth main process (1795) killed by TERM signal
upstart: indicator-power main process (1796) killed by TERM signal
upstart: indicator-datetime main process (1797) killed by TERM signal
upstart: indicator-application main process (1844) killed by TERM signal
upstart: job window-stack-bridge failed to stop
Thanks, David
David
Set appropriate ownership to .Xauthority and .ICEauthority.
chown username:username .Xauthority
chown username:username .ICEauthority
Set permission for /tmp
sudo chmod a+wt /tmp
Restart lightdm
dpkg-reconfigure lightdm
sudo service lightdm restart
Reboot and login, this should fix your problem, if not then remove incompatible graphics driver:
For Nvidia:
sudo nvidia-settings --uninstall
sudo apt-get remove --purge nvidia*
For amd:
sudo apt-get purge fglrx*
Rahul
  • 1,683
