Mounting external HD Seagate 4 TB in Kubuntu failed with error message:
Error mounting /dev/sda1 at /media/fritz/Seagate Backup Plus Drive: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000" "/dev/sda1" "/media/fritz/Seagate Backup Plus Drive"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda1': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
However, mounting with Windows 8.1 was OK.
How can I mount with kubuntu again ?
Boot into Windows.
First we check/fix the disk structure, then we turn off fast start and hibernation.
  • in an administrative command prompt window, type chkdsk /f D: and change the D to the appropriate drive letter
  • open power control panel, choose Change what power buttons do, then choose Change options that are unavailable, then uncheck Fast Start
  • in an administrative command prompt window, type powercfg /h off
Then reboot into kubuntu and all should be well.
heynnema
  • 73,649
