This Github Gist by srguiwiz shows a prompt with colours based on branch status:
# http://henrik.nyh.se/2008/12/git-dirty-prompt
# http://www.simplisticcomplexity.com/2008/03/13/show-your-git-branch-name-in-your-prompt/
# username@Machine ~/dev/dir [master]$ # clean working directory green
# username@Machine ~/dev/dir [master*]$ # dirty working directory red*
function git_branch {
git branch --no-color 2> /dev/null | sed -e '/^[^*]/d' -e 's/* \(.*\)/\1/'
# http://unix.stackexchange.com/questions/88307/escape-sequences-with-echo-e-in-different-shells
function markup_git_branch {
if [[ "x$1" = "x" ]]; then
echo -e "[$1]"
else
if [[ $(git status 2> /dev/null | tail -n1) = "nothing to commit, working directory clean" ]]; then
echo -e '\033[1;32m['"$1"']\033[0;0m'
else
echo -e '\033[1;31m['"$1"'*]\033[0;0m'
fi
fi
export PS1='\u@\h \[\033[0;34m\]\w\[\033[0m\] $(markup_git_branch $(git_branch))$ '
You only need to use $(markup_git_branch $(git_branch)) in your prompt, wherever you want show the commit status and branch.
There's a slight change to original code here: the \033[0;30m at the end should be \033[0;0m to reset the prompt colour. The former sets it black, the latter resets formatting on the text.
srguiwiz's code seems to have some problems, jcgoble3 made a better version:
# Adds the current branch to the bash prompt when the working directory is
# part of a Git repository. Includes color-coding and indicators to quickly
# indicate the status of working directory.
# To use: Copy into ~/.bashrc and tweak if desired.
# Based upon the following gists:
# <https://gist.github.com/henrik/31631>
# <https://gist.github.com/srguiwiz/de87bf6355717f0eede5>
# Modified by me, using ideas from comments on those gists.
# License: MIT, unless the authors of those two gists object :)
git_branch() {
# -- Finds and outputs the current branch name by parsing the list of
# all branches
# -- Current branch is identified by an asterisk at the beginning
# -- If not in a Git repository, error message goes to /dev/null and
# no output is produced
git branch --no-color 2>/dev/null | sed -e '/^[^*]/d' -e 's/* \(.*\)/\1/'
git_status() {
# Outputs a series of indicators based on the status of the
# working directory:
# + changes are staged and ready to commit
# ! unstaged changes are present
# ? untracked files are present
# S changes have been stashed
# P local commits need to be pushed to the remote
local status="$(git status --porcelain 2>/dev/null)"
local output=''
[[ -n $(egrep '^[MADRC]' <<<"$status") ]] && output="$output+"
[[ -n $(egrep '^.[MD]' <<<"$status") ]] && output="$output!"
[[ -n $(egrep '^\?\?' <<<"$status") ]] && output="$output?"
[[ -n $(git stash list) ]] && output="${output}S"
[[ -n $(git log --branches --not --remotes) ]] && output="${output}P"
[[ -n $output ]] && output="|$output" # separate from branch name
echo $output
git_color() {
# Receives output of git_status as argument; produces appropriate color
# code based on status of working directory:
# - White if everything is clean
# - Green if all changes are staged
# - Red if there are uncommitted changes with nothing staged
# - Yellow if there are both staged and unstaged changes
local staged=$([[ $1 =~ \+ ]] && echo yes)
local dirty=$([[ $1 =~ [!\?] ]] && echo yes)
if [[ -n $staged ]] && [[ -n $dirty ]]; then
echo -e '\033[1;33m' # bold yellow
elif [[ -n $staged ]]; then
echo -e '\033[1;32m' # bold green
elif [[ -n $dirty ]]; then
echo -e '\033[1;31m' # bold red
else
echo -e '\033[1;37m' # bold white
fi
git_prompt() {
# First, get the branch name...
local branch=$(git_branch)
# Empty output? Then we're not in a Git repository, so bypass the rest
# of the function, producing no output
if [[ -n $branch ]]; then
local state=$(git_status)
local color=$(git_color $state)
# Now output the actual code to insert the branch and status
echo -e "\x01$color\x02[$branch$state]\x01\033[00m\x02" # last bit resets color
fi
# Sample prompt declaration based off of the default Ubuntu 14.04.1 color
# prompt. Tweak as you see fit, or just stick "$(git_prompt)" into your
# favorite prompt.
PS1='$debian_chroot\[\033[01;32m\]\u@\h\[\033[00m\]:\[\033[01;34m\]\w$(git_prompt)\[\033[00m\]\$ '
