I try to change the external monitor refresh rate for my IIYAMA PROLITE X4071UHSU-B1 Monitor on a XNG p406 Laptop. I'm using the internal Intel GPU.
xrandr gives me:
eDP1 connected primary 1920x1080+0+961 (normal left inverted right x axis y axis) 309mm x 174mm
   1920x1080     60.02*+  59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1600x900      60.00
DP1 connected 3840x2160+1920+0 (normal left inverted right x axis y axis) 878mm x 485mm
   3840x2160     60.00 +  30.00*   29.97
   1920x2160     60.00
   2560x1440     59.95
   2048x1152     60.00
So, 60Hz should be available, but is not used.
So I try to switch to 60 hz with xrandr --output DP1 --rate 60. But nothing happens. No output in the console, no flickering or something. And xrandr gives the same output like above.
Am I doing something wrong?
My Ubuntu: 16.04 With 4.7.2-040702-generic kernel
jiipeezz pointed me to the right direction: I edited the file ~/.config/monitors.xml with the command sudo gedit ~/.config/monitors.xml and changed <rate>30</rate> to <rate>60</rate> and rebooted. Now it works, xrandr output is:
   3840x2160     60.00*+  30.00    29.97
   1920x2160     60.00
   2560x1440     59.95
