In Windows I used an RSS feed to download a tv series, but Deluge doesnt have that option. Is there a plugin to add that fuction? How do I install and configure it?
If there isn't a plugin which client do you recomend?
I don't think there's a plugin for Deluge, but flexget is an RSS torrent downloader that is very easy to configure, extremely flexible and has tight integration to Deluge. I use flexget+Deluge and it works fine.
Take a look at this for details on Deluge integration
I don't think Deluge has an rss feed downloader, but qBitTorrent does and is an excellent client.
See Comparison of BitTorrent clients
KTorrent has rss feed and is an excellent client. If you are using Gnome, then it will install "some" dependencies too, because is a KDE application.
A little late to the discussion, but...
Deluge has an RSS plugin called YaRSS2. Vuze can handle RSS, too, but it's written in java and so it doesn't integrate well with GNOME. The slightly beefier Miro can, as well, but it either has a bug or plays nanny about what torrents you can download. If you want to use Transmission, there's an insanely complicated-looking setup described here on Ubuntu Forums
I prefer rtorrent + rtgui, a web GUI for rtorrent. If you do this, make sure to manually install the latest libtorrent and rtorrent (which needs to configured --with-xmlrpc-c). These directions are basically what you need to do, but make sure you use the latest and greatest versions of everything.
