while running sudo apt-get upgrade, I stumbled this problem:
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 php5.6-fpm : Depends: php5.6-common (= 5.6.26-2+deb.sury.org~precise+1) but 5.6.28-1+deb.sury.org~precise+1 is installed
E: Unmet dependencies. Try using -f.
then after I do the suggestion by running sudo apt-get -f install, the new error message shows:
dpkg: dependency problems prevent configuration of php5.6-fpm:
 php5.6-fpm depends on php5.6-common (= 5.6.26-2+deb.sury.org~precise+1); however:
  Version of php5.6-common on system is 5.6.28-1+deb.sury.org~precise+1.
dpkg: error processing php5.6-fpm (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 php5.6-fpm
I could not remove php5.6-fpm either because it also return Sub-process /usr/bin/dpkg returned an error code (1)
It seems the php5.6-fpm has different dependencies but cannot upgraded or removed because there is a configuration missing
karel
  • 122,292
  • 133
  • 301
  • 332
Zuzu Softman
  • 101
A way to meet all required dependencies, is to install the lamp package by running the command below (including the ^ symbol)
sudo apt-get install lamp-server^
michael
  • 254
