I just installed Ubuntu on my PC. I used the "Install alongside Windows 10" option. Whenever I boot my PC up the only option I get is Ubuntu. Any help will be greatly appreciated.
I wasn't able to get pictures but when I boot I go to a purple screen where the only option is Ubuntu and two other things (Something like Ubuntu recovery)
Here is the output of fdisk -l
$ sudo fdisk -l
Disk /dev/ram0: 64 MiB, 67108864 bytes, 131072 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/ram1: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram2: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram3: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram4: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram5: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram6: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram7: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram8: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram9: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram10: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram11: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram12: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram13: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram14: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram15: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Disklabel type: dos
Disk identifier: 0x03af3d81
Device     Boot      Start        End    Sectors   Size Id Type
/dev/sda1  *          2048    1026047    1024000   500M  7 HPFS/NTFS/exFAT
/dev/sda2          1026048 1543919615 1542893568 735.7G  7 HPFS/NTFS/exFAT
/dev/sda3       1543921662 1953523711  409602050 195.3G  5 Extended
/dev/sda5       1543921664 1920126975  376205312 179.4G 83 Linux
/dev/sda6       1920129024 1953523711   33394688  15.9G 82 Linux swap / Solaris
Partition 3 does not start on physical sector boundary.
Disk /dev/sdb: 28.7 GiB, 30752000000 bytes, 60062500 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x2c361bca
/dev/sdb1  *     2048 60062499 60060452 28.7G  c W95 FAT32 (LBA)
David Foerster
  • 36,890
  • 56
  • 97
  • 151
