When I right-click on an application's icon on the launcher, and select "Lock to launcher", the contextual menu never disappears. Despite that, pressing escape to get out of the menu and then closing the application does not remove the icon, suggesting to me that it "worked".
But on the other hand, when I do the same for "Unlock from launcher", the icon still remains. I don't have a way to remove the icon after it's been locked to the launcher.
Additionally, when I click-and-hold an icon for 2 seconds to move the icon, the icon appears to follow/be anchored to the cursor to allow me to move it. However, subsequently clicking the mouse anywhere does not release the icon to be moved; instead I have to right-click or press escape to cancel.
I'm sure you can imagine my frustration at this. Please help.
I have tried:
...but of course I still am unable to lock or move icons or I wouldn't be here. Any thoughts on what I might be doing wrong or how to figure out what's broken?
Are there error or message logs I can look at? Are there specific executables or permissions I can look at? What configuration files are related to the applications here?
inetknght
  • 135
Find the associated .desktop file and remove it.
Look for the .desktop file in these folders:
/usr/share/applications
~/.local/share/applications/
When you find it, remove the file with sudo rm -f file.desktop. Next time you reboot it should be gone. If you can't find it, you can always search the entire hard drive with:
sudo find / -name "*.desktop"
Katu
  • 3,663
It appears that the problem is the with unity. So these steps should help, open terminal then run following command:
 sudo apt-get update
 sudo apt-get install --reinstall ubuntu-desktop
 sudo apt-get install unity
if the above don't work try resetting unity using the following commands in the terminal
 dconf reset -f /org/compiz/
 setsid unity
And this should give you back the default icons if you need them
 unity --reset-icons
George Udosen
  • 37,534
