Is there an alternative to Startup Disk Creator for creating a bootable usb in Ubuntu 16.04 ?
Asked
Active
Viewed 3.8k times
Best is the dd command as other alternatives including Startup Disk Creator often gives errors with newer versions of linux. The command is sudo dd bs=4M if=/path/to/.iso of=/dev/sdx && sync
Remember to unmount the USB and check the device name with lsblk command and change the sdx with appropriate device name in the command.
Gautam Vashisht
- 2,635
Arijit Chatterjee
- 1,173
UNetbootin is a great alternative of Startup Disk Creator. UNetbootin (Universal Netboot Installer) is a cross-platform utility that can create live USB systems and can load a variety of system utilities or install various Linux distributions and other operating systems without a CD. You can install UNetbootin in Ubuntu 16.04 by running the commands given below from terminal :-
sudo add-apt-repository ppa:gezakovacs/ppa
sudo apt-get update
sudo apt-get install unetbootin
References : UNetbootin - Wikipedia
