I d like to ask a clean removal method, so that python 3 will not be diturbed by previous version. I am not sure how the python2.7 be installed, because it was not me who did it. And i am totally new in Linux, so I really not sure what should I do...
Here is the information when I check the python version. Thanks!! :)
administrator@TUBVLMF-AWR163:~$ python -v
# installing zipimport hook
import zipimport # builtin
# installed zipimport hook
# /usr/bin/anaconda/lib/python2.7/site.pyc matches /usr/bin/anaconda/lib/python2.7/site.py
import site # precompiled from /usr/bin/anaconda/lib/python2.7/site.pyc
# /usr/bin/anaconda/lib/python2.7/os.pyc matches /usr/bin/anaconda/lib/python2.7/os.py
import os # precompiled from /usr/bin/anaconda/lib/python2.7/os.pyc
import errno # builtin
import posix # builtin
# /usr/bin/anaconda/lib/python2.7/posixpath.pyc matches /usr/bin/anaconda/lib/python2.7/posixpath.py
import posixpath # precompiled from /usr/bin/anaconda/lib/python2.7/posixpath.pyc
# /usr/bin/anaconda/lib/python2.7/stat.pyc matches /usr/bin/anaconda/lib/python2.7/stat.py
import stat # precompiled from /usr/bin/anaconda/lib/python2.7/stat.pyc
# /usr/bin/anaconda/lib/python2.7/genericpath.pyc matches /usr/bin/anaconda/lib/python2.7/genericpath.py
import genericpath # precompiled from /usr/bin/anaconda/lib/python2.7/genericpath.pyc
# /usr/bin/anaconda/lib/python2.7/warnings.pyc matches /usr/bin/anaconda/lib/python2.7/warnings.py
import warnings # precompiled from /usr/bin/anaconda/lib/python2.7/warnings.pyc
# /usr/bin/anaconda/lib/python2.7/linecache.pyc matches /usr/bin/anaconda/lib/python2.7/linecache.py
import linecache # precompiled from /usr/bin/anaconda/lib/python2.7/linecache.pyc
# /usr/bin/anaconda/lib/python2.7/types.pyc matches /usr/bin/anaconda/lib/python2.7/types.py
import types # precompiled from /usr/bin/anaconda/lib/python2.7/types.pyc
# /usr/bin/anaconda/lib/python2.7/UserDict.pyc matches /usr/bin/anaconda/lib/python2.7/UserDict.py
import UserDict # precompiled from /usr/bin/anaconda/lib/python2.7/UserDict.pyc
# /usr/bin/anaconda/lib/python2.7/_abcoll.pyc matches /usr/bin/anaconda/lib/python2.7/_abcoll.py
import _abcoll # precompiled from /usr/bin/anaconda/lib/python2.7/_abcoll.pyc
# /usr/bin/anaconda/lib/python2.7/abc.pyc matches /usr/bin/anaconda/lib/python2.7/abc.py
import abc # precompiled from /usr/bin/anaconda/lib/python2.7/abc.pyc
# /usr/bin/anaconda/lib/python2.7/_weakrefset.pyc matches /usr/bin/anaconda/lib/python2.7/_weakrefset.py
import _weakrefset # precompiled from /usr/bin/anaconda/lib/python2.7/_weakrefset.pyc
import _weakref # builtin
# /usr/bin/anaconda/lib/python2.7/copy_reg.pyc matches /usr/bin/anaconda/lib/python2.7/copy_reg.py
import copy_reg # precompiled from /usr/bin/anaconda/lib/python2.7/copy_reg.pyc
# /usr/bin/anaconda/lib/python2.7/traceback.pyc matches /usr/bin/anaconda/lib/python2.7/traceback.py
import traceback # precompiled from /usr/bin/anaconda/lib/python2.7/traceback.pyc
# /usr/bin/anaconda/lib/python2.7/sysconfig.pyc matches /usr/bin/anaconda/lib/python2.7/sysconfig.py
import sysconfig # precompiled from /usr/bin/anaconda/lib/python2.7/sysconfig.pyc
# /usr/bin/anaconda/lib/python2.7/re.pyc matches /usr/bin/anaconda/lib/python2.7/re.py
import re # precompiled from /usr/bin/anaconda/lib/python2.7/re.pyc
# /usr/bin/anaconda/lib/python2.7/sre_compile.pyc matches /usr/bin/anaconda/lib/python2.7/sre_compile.py
import sre_compile # precompiled from /usr/bin/anaconda/lib/python2.7/sre_compile.pyc
import _sre # builtin
# /usr/bin/anaconda/lib/python2.7/sre_parse.pyc matches /usr/bin/anaconda/lib/python2.7/sre_parse.py
import sre_parse # precompiled from /usr/bin/anaconda/lib/python2.7/sre_parse.pyc
# /usr/bin/anaconda/lib/python2.7/sre_constants.pyc matches /usr/bin/anaconda/lib/python2.7/sre_constants.py
import sre_constants # precompiled from /usr/bin/anaconda/lib/python2.7/sre_constants.pyc
# /usr/bin/anaconda/lib/python2.7/_sysconfigdata.pyc matches /usr/bin/anaconda/lib/python2.7/_sysconfigdata.py
import _sysconfigdata # precompiled from /usr/bin/anaconda/lib/python2.7/_sysconfigdata.pyc
# zipimport: found 13 names in /usr/bin/anaconda/lib/python2.7/site-packages/runipy-0.1.0-py2.7.egg
# zipimport: found 135 names in /usr/bin/anaconda/lib/python2.7/site-packages/setuptools-3.6-py2.7.egg
import encodings # directory /usr/bin/anaconda/lib/python2.7/encodings
# /usr/bin/anaconda/lib/python2.7/encodings/__init__.pyc matches /usr/bin/anaconda/lib/python2.7/encodings/__init__.py
import encodings # precompiled from /usr/bin/anaconda/lib/python2.7/encodings/__init__.pyc
# /usr/bin/anaconda/lib/python2.7/codecs.pyc matches /usr/bin/anaconda/lib/python2.7/codecs.py
import codecs # precompiled from /usr/bin/anaconda/lib/python2.7/codecs.pyc
import _codecs # builtin
# /usr/bin/anaconda/lib/python2.7/encodings/aliases.pyc matches /usr/bin/anaconda/lib/python2.7/encodings/aliases.py
import encodings.aliases # precompiled from /usr/bin/anaconda/lib/python2.7/encodings/aliases.pyc
# /usr/bin/anaconda/lib/python2.7/encodings/utf_8.pyc matches /usr/bin/anaconda/lib/python2.7/encodings/utf_8.py
import encodings.utf_8 # precompiled from /usr/bin/anaconda/lib/python2.7/encodings/utf_8.pyc
Python 2.7.7 |Anaconda 2.0.1 (64-bit)| (default, Jun  2 2014, 12:34:02)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-54)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
Anaconda is brought to you by Continuum Analytics.
Please check out: http://continuum.io/thanks and https://binstar.org
dlopen("/usr/bin/anaconda/lib/python2.7/lib-dynload/readline.so", 2);
import readline # dynamically loaded from /usr/bin/anaconda/lib/python2.7/lib-dynload/readline.so
muru
  • 207,228
By default in latest Ubuntu release python and python3 are already included and if you completely remove python 2.7 it may break your system type in terminal
python3
to open python 3 interpreter and when you run your scripts type
python3 Scriptname
and if not already included type in terminal
sudo apt-get update && sudo apt-get install python3
have fun :)
First, to check if YOU have manually installated python2.7, do
apt show python2.7
Within all this infos there's a line APT-Manual-Installed: no. If this is NO you shouldn't probably uninstall it! For all packages, this rule is often true.
So, as said it isn't wise removing python2.7. I suggest to add simply an alias to your bash's configuration file, so when you'll write python in your terminal, it will be like writing python3. This is useful, but potentially can create misunderstanding.
HOW TO DO
Add
alias python=python3
at the bottom of ~/.bashrc file (or simply echo "alias python=python3" >> ~/.bashrc)
Than do:
source ~/.bashrc
from the terminal to update bash with the changes.
Cirelli94
  • 626
  • 26
