I followed a tutorial to install asterisk 13 and freepbx 13 on Ubuntu 14.04 but I was installing on 16.04. I finish all the steps but when I point my browser to the freepbx server I can't see anything coming up for me to log on to web interface. When I do this http://192.168.122.180/admin I get this error
You don't have permission to access /admin on this server. Server unable to read htaccess file, denying access to be safe
Apache/2.4.18 (Ubuntu) Server at 192.168.122.182 Port 80
I want to use Ubuntu not CentOS freepbx system
My Apache configuration is:
<VirtualHost *:80>
ServerAdmin systems@domain.com
ServerName domain.com
DocumentRoot /var/www/html/admin
<Directory /var/www/html/admin/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
</VirtualHost>
You have mixed and matched your virtual site directives. Apache has changed the configuration a bit from 2.2 to 2.4, namely the access control.
2.2 configuration:
Order allow,deny Allow from all
2.4 configuration:
Require all granted
As you can see, you're using a 2.2 configuration on what I am assuming is apache 2.4.
The following should work for you.
<VirtualHost *:80>
Require all granted
</Directory>
</VirtualHost>
didn't you encountered what they encountered using FreePBX on Ubuntu 16.04? Check this link https://community.freepbx.org/t/freepbx-install-issues-on-ubuntu-16-04-lts/36363. Im planning to use Ubuntu 16.10 on my NUC7i7BNH and install Asterisk and FreePBX. Thanks.
