I am trying to install driver for my TP-Link wireless adapter TL-WN8200ND on Ubuntu 16.04.
Without installing any driver manually, wireless networks are present but when I connect it shows a status of disconnected and doesn't work.
I assume this is a driver related issue, so I tried different solutions I found:
  1. TL-WN8200ND wireless adapter is sopported on linux?
The given driver rtl8192cu-dkms wasn't present in the repository.
  1. Compile and install rtl8192cu driver
It was installed correctly but the problem persisted.
  1. I also tried installing rtlwifi-new-dkms but the problem persisted.
I don't know What to do next? Is there anything I am doing wrong or missing any step?
Here's my wireless hardware related info.
The result of sudo lshw -class network is
  *-network
       description: Ethernet interface
       product: 82545EM Gigabit Ethernet Controller (Copper)
       vendor: Intel Corporation
       physical id: 1
       bus info: pci@0000:02:01.0
       logical name: ens33
       version: 01
       serial: 00:0c:29:53:6d:a1
       capacity: 1Gbit/s
       width: 64 bits
       clock: 66MHz
       capabilities: pm pcix bus_master cap_list rom ethernet physical logical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000 driverversion=7.3.21-k8-NAPI duplex=full ip=192.168.147.129 latency=0 link=yes mingnt=255 multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:19 memory:fd5c0000-fd5dffff memory:fdff0000-fdffffff ioport:2000(size=64) memory:fd500000-fd50ffff
  *-network
       description: Wireless interface
       physical id: 1
       bus info: usb@1:1
       logical name: wlx60e327096b82
       serial: 60:e3:27:09:6b:82
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8192cu driverversion=4.4.0-47-generic firmware=N/A link=no multicast=yes wireless=IEEE 802.11bgn
The result of lsusb
Bus 001 Device 002: ID 2357:0100
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
The result of rfkill list all
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
The result of lspci is
00:00.0 Host bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 01)
00:01.0 PCI bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 01)
00:07.0 ISA bridge: Intel Corporation 82371AB/EB/MB PIIX4 ISA (rev 08)
00:07.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01)
00:07.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 08)
00:07.7 System peripheral: VMware Virtual Machine Communication Interface (rev 10)
00:0f.0 VGA compatible controller: VMware SVGA II Adapter
00:10.0 SCSI storage controller: LSI Logic / Symbios Logic 53c1030 PCI-X Fusion-MPT Dual Ultra320 SCSI (rev 01)
00:11.0 PCI bridge: VMware PCI bridge (rev 02)
00:15.0 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.1 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.2 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.3 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.4 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.5 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.6 PCI bridge: VMware PCI Express Root Port (rev 01)
00:15.7 PCI bridge: VMware PCI Express Root Port (rev 01)
00:16.0 PCI bridge: VMware PCI Express Root Port (rev 01)
00:16.1 PCI bridge: VMware PCI Express Root Port (rev 01)
00:16.2 PCI bridge: VMware PCI Express Root Port (rev 01)
00:16.3 PCI bridge: VMware PCI Express Root Port (rev 01)
00:16.4 PCI bridge: VMware PCI Express Root Port (rev 01)
00:16.5 PCI bridge: VMware PCI Express Root Port (rev 01)
00:16.6 PCI bridge: VMware PCI Express Root Port (rev 01)
00:16.7 PCI bridge: VMware PCI Express Root Port (rev 01)
00:17.0 PCI bridge: VMware PCI Express Root Port (rev 01)
00:17.1 PCI bridge: VMware PCI Express Root Port (rev 01)
00:17.2 PCI bridge: VMware PCI Express Root Port (rev 01)
00:17.3 PCI bridge: VMware PCI Express Root Port (rev 01)
00:17.4 PCI bridge: VMware PCI Express Root Port (rev 01)
00:17.5 PCI bridge: VMware PCI Express Root Port (rev 01)
00:17.6 PCI bridge: VMware PCI Express Root Port (rev 01)
00:17.7 PCI bridge: VMware PCI Express Root Port (rev 01)
00:18.0 PCI bridge: VMware PCI Express Root Port (rev 01)
00:18.1 PCI bridge: VMware PCI Express Root Port (rev 01)
00:18.2 PCI bridge: VMware PCI Express Root Port (rev 01)
00:18.3 PCI bridge: VMware PCI Express Root Port (rev 01)
00:18.4 PCI bridge: VMware PCI Express Root Port (rev 01)
00:18.5 PCI bridge: VMware PCI Express Root Port (rev 01)
00:18.6 PCI bridge: VMware PCI Express Root Port (rev 01)
00:18.7 PCI bridge: VMware PCI Express Root Port (rev 01)
02:00.0 USB controller: VMware USB1.1 UHCI Controller
02:01.0 Ethernet controller: Intel Corporation 82545EM Gigabit Ethernet Controller (Copper) (rev 01)
02:02.0 Multimedia audio controller: Ensoniq ES1371 / Creative Labs CT2518/ES1373 (rev 02)
02:03.0 USB controller: VMware USB2 EHCI Controller
02:05.0 SATA controller: VMware SATA AHCI controller
Zanna
  • 72,312
I found this procedure to correctly install driver for TP-LINK WN8200ND. Use this GitHub repository.
  1. Follow the installation procedure.
  2. Reboot machine (My is Ubuntu 16.04.03 LTS)
  3. Plug-in USBWIFI
and voila it works :))
Zanna
  • 72,312
