I am new to Linux and I want to create an alias to run an application.
Currently, to access it via the terminal I am typing:
cd /usr/local/bin
packettracer
Is there any way I can by pass creating an alias just to change directories? I just want to be able to type pt for example into the terminal and it instantly run, rather than typing two separate commands.
Thank you in advance!
When you type echo $PATH you should see /usr/local/bin is already in your path and there is no need to change to that directory in the first place. You can run the executable simply by typing packettracer - there is no need to cd to it.
Even if it is not in your PATH, you don't need to change to a program's / script's directory as a separate command; you can run it by prefixing the executable's name with the full path, in this case:
/usr/local/bin/packettracer
Therefore your alias can simply be:
alias pt='/usr/local/bin/packettracer'
or even
alias pt='packettracer'
Before setting an alias, check that the command you want to use doesn't already exist using the type command. Hopefully you will see that it is not in use:
$ type pt
bash: type: pt: not found
Once you have a suitable alias, to make is permanent you can add it to the end of your ~/.bashrc file (use your favourite text editor; for example, open a terminal and type nano .bashrc add the alias, save and exit, and the alias will be available as soon as you open a new shell).
Zanna
  • 72,312
