14
This question has been asked many times for Ubuntu 11.10 but it always has been closed and linked with this link, but that accepted answer is from 2010 and that setting doesn't work anymore for Ubuntu 11.10. Furthermore, the brightness setting doesn't exist anymore in "Energy" options. It is now on "Screen" options and it doesn't seem to remember the setting after reboot.
So, how to make Unity remember brightness settings?
Teresa H
  • 149
The short answer is: you can't. Gnome power manager doesn't save the brightness setting. The best you can do is to automatically set it to a reasonable default at startup.
For 11.10, the only solution I have found that works is the one given here: http://blog.ishans.info/2011/09/25/set-brightness-automatically-at-the-startup-in-linux/
Save http://ishans.info/attachments/article/65/setBrightness.py locally, change the brightness percentage in the last line to your preferred value, and add a new startup application to run:
python /wherever-you-saved-the-script/setBrightness.py
jpd
  • 1,040
I haven't found a way to get Ubuntu (I'm currently using 13.04) to save the last used brightness settings, but the default brightness of 100% on my laptop was too bright, and forced me to find a workaround (using the link denrossalenga provided).
Just add a line like this to your /etc/rc.local file:
echo 60 > /sys/class/backlight/acpi_video0/brightness
This will give you a startup brightness of 60%. Change as appropriate.
ltn100
  • 220
I know it's been a long time. But I still gonna answer it as it appears in Google search.
If you dont have xbacklight installed than install it
sudo apt-get install xbacklight
Now what is left to do is to do the remembering the brightness and applying on log in.
sudo sed -i '$ixbacklight | cat > ~/.brightness' /etc/gdm/PostSession/Default
touch ~/.gnomerc
echo 'b=$(cat ~/.brightness)' >> ~/.gnomerc
echo 'xbacklight -set $b' >> ~/.gnomerc
This will remember the brightness form the time of shutdown and set it back as soon as you log in to your user.
ashik992
  • 171
-1
You may try this one! This one solved my problem :D
http://ubuntuguide.net/how-to-save-screen-brightness-settings-in-ubuntu-12-04-laptop
