As the solution to another problem I was forced to use dpkg --remove to uninstall a package. However, after I do this the package is still listed in dpkg -l:
phrogz@planar:/boot$ dpkg -l | grep linux-image-2
ii linux-image-2.6.32-30-server 2.6.32-30.59 Linux kernel image for version 2.6.32 on x86
ii linux-image-2.6.32-31-server 2.6.32-31.61 Linux kernel image for version 2.6.32 on x86
ii linux-image-2.6.32-32-server 2.6.32-32.62 Linux kernel image for version 2.6.32 on x86
phrogz@planar:/boot$ sudo dpkg --remove linux-image-2.6.32-30-server
(Reading database ... 141902 files and directories currently installed.)
Removing linux-image-2.6.32-30-server ...
Running postrm hook script /usr/sbin/update-grub.
Generating grub.cfg ...
done
rc linux-image-2.6.32-30-server 2.6.32-30.59 Linux kernel image for version 2.6.32 on x86
phrogz@planar:/boot$ sudo apt-get --purge remove linux-image-2.6.32-30-server
Reading package lists... Done
Building dependency tree
Package linux-image-2.6.32-30-server is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
How can I 'clean house' so that dpkg-l no longer lists these older, non-existent packages?
