12
I've just downloaded Ninja IDE and I really like it's interface.
Is there a way to configure the Quickly app to launch my project in Ninja IDE when I type quickly edit?
Nootrino
  • 657
quickly should support the EDITOR environmental variable.
$ quickly help ubuntu-application edit
Usage: quickly edit
A convenience command to open all of your python files in your project
directory in your default editor, ready for editing.
If you put yourself EDITOR or SELECTED_EDITOR environment variable, this latter
will be used. Also, if you configured sensible-editor, this one will be
choosed.
I don't have any other GUI IDEs installed, but I tested it with $ export EDITOR=nano && quickly edit and all files were opened in nano instead of gedit. Adding export EDITOR=nano to your ~/.bashrc should make this change persistent.
If you don't want to change the default editor for your system you could just use
export QUICKLY_EDITOR="yourpreferrededitorhere"
I found this somewhere on the net, so credits go to the guy who discovered this solution.
Cheers
Phoenix87
  • 606
