After this I get this
$ sudo apt update
$ sudo apt upgrade
$ sudo apt install -f
$ sudo apt install vlc
billn@billn-N107:~$ sudo apt install vlc
Reading package lists... Done
Building dependency tree
vlc : Depends: vlc-nox (= 2.2.2-5) but 2.2.4-6~ubuntu16.04.1~ppa1 is to be installed
Recommends: vlc-plugin-notify (= 2.2.2-5) but it is not going to be installed
Recommends: vlc-plugin-samba (= 2.2.2-5) but it is not going to be installed
billn@billn-N107:~$
