Both cron and anacron are daemons that can schedule execution of recurring tasks to a certain point in time defined by the user.
The main difference between cron and anacron is that the former assumes that the system is running continuously. If your system is off and you have a job scheduled during this time, the job never gets executed.
On the other hand anacron is 'anachronistic' and is designed for systems that are not running 24x7. For it to work anacron uses time-stamped files to find out when the last time its commands were executed. It also maintains a file /etc/anacrontab just like cron does. In addition, cron.daily runs anacron every day. Hence, anacron can only run a job once a day, but cron can run as often as every minute.
From man anacrontab:
When executed, Anacron reads a list of jobs from a configuration file,
normally
/etc/anacrontab (see anacrontab(5)). This file contains the list of jobs that
Anacron controls. Each job entry specifies a period in days, a delay in minutes, a unique job identifier, and a shell command.
For each job, Anacron checks whether this job has been executed in
the last n
days, where n is the period specified for that job. If not, Anacron runs the
job's shell command, after waiting for the number of minutes specified as the
delay parameter.
After the command exits, Anacron records the date in a special
timestamp file
for that job, so it can know when to execute it again. Only the date is used
for the time calculations. The hour is not used.
This means, if a task is scheduled to be run daily and the computer was turned off during that time, when anacron is run, it can see that the task was last run more than 24 hours ago and execute the task correctly.
For example if you specify the following in /etc/anacrontab:
7 15 test.daily /bin/sh /home/username/script.sh
and on the day when the script.sh job is supposed to executed, if the system is not running, anacron will execute the script.sh 15 minutes after the system comes back up.
Few Reference:
