14
As it is the only way to activate transparent themes in Gnome-shell:
  • How to disable Nautilus from handling the desktop?
  • Can I make it handle the desktop again?
  • What will happen to the unity and desktop icons?
  • How to handle the desktop icons without nautilus?
Black Block
  • 5,139
I found that running gsettings set org.gnome.desktop.background show-desktop-icons false instantly disabled the desktop icons.
Jon Wood
  • 221
You should remove the file /etc/xdg/autostart/nautilus-autostart.desktop (or at least modify the OnlyShowIn line into it).
Then you should always run nautilus with the --no-desktop option (this could also require to modify some menu item or quicklist).
You can manage the desktop with nautilus again at any time launching nautilus without the option --no-desktop.
To manage the desktop in an alternative way you could look at some other file manager.
enzotib
  • 96,093
If you install the gnome tweak tool (which you'll want anyway) you can disable file manager handling the desktop (see Picture). But as far as I know you will then have no desktop icons. Most if not all DEs are structured such that the file manager handles desktop icons.
d
bob
  • 51
