I tried to compile a scheme file with CHICKEN and it says there that I need to install the iup port of CHICKEN. So I went to the website and tried to install the iup port but I got an error. Then I realized I need to get ffcall. I got that installed and tried to install the iup port again. And failed. I don't know if I got srfi-42 installed on my system. Even if I know it's not installed I still don't know how to install srfi-42 to get the iup port to work.
This is the error that I get:
    ander@Ander:~/blah/chicken-4.11.0/chicken-4.11.0$ sudo chicken-install iup
retrieving ...
connecting to host "chicken.kitten-technologies.co.uk", port 80 ...
requesting "/henrietta.cgi?name=iup&mode=default" ...
reading response ...
HTTP/1.1 200 OK
Date: Sat, 12 Nov 2016 06:16:26 GMT
Server: Apache/2.2.31 (Unix) DAV/2 PHP/5.5.36 mod_fastcgi/2.4.6
Connection: close
Transfer-Encoding: chunked
Content-Type: text/plain
reading chunks ....
reading files ...
  ./iup-controls.scm
  ./iup-base.scm
  ./iup-config.scm
  ./iup-glcanvas.scm
  ./iup-dialogs.scm
  ./iup-dynamic.scm
  ./iup-glcontrols.scm
  ./iup-mglplot.scm
  ./iup-ole.scm
  ./iup-plot.scm
  ./iup-pplot.scm
  ./iup-scintilla.scm
  ./iup-types.scm
  ./iup-web.scm
  ./iup.meta
  ./iup.release-info
  ./iup.scm
  ./iup.setup
 iup located at /tmp/temp5d54.6346/iup
checking platform for `iup' ...
checking dependencies for `iup' ...
install order:
("iup")
installing iup:1.8.0 ...
changing current directory to /tmp/temp5d54.6346/iup
  '/usr/local/bin/csi' -bnq -setup-mode -e "(require-library setup-api)" -e "(import setup-api)" -e "(setup-error-handling)" -e "(extension-name-and-version '(\"iup\" \"1.8.0\"))" 'iup.setup'
  '/usr/local/bin/csc' -feature compiling-extension -setup-mode    -s -O2 -d1 iup.scm -j iup -j iup-base -j iup-controls -j iup-dialogs -j iup-glcanvas -j iup-glcontrols -j iup-plot -j iup-mglplot -j iup-pplot -j iup-scintilla -j iup-web -j iup-config -lcallback -liup -liupim -liupimglib -liupcontrols -liupmatrixex -liupgl -liupglcontrols -liup_plot -liup_mglplot -liup_pplot -liup_scintilla -liupweb
iup.c:17:16: fatal error: im.h: No such file or directory
compilation terminated.
Error: shell command terminated with non-zero exit status 256: 'gcc' 'iup.c' -o 'iup.o' -c  -fno-strict-aliasing -fwrapv -DHAVE_CHICKEN_CONFIG_H -DC_ENABLE_PTABLES -Os -fomit-frame-pointer -fPIC -DPIC -DC_SHARED -I/usr/local/include/chicken
Error: shell command failed with nonzero exit status 256:
Error: shell command terminated with nonzero exit code
17920
"'/usr/local/bin/csi' -bnq -setup-mode -e \"(require-library setup-api)\" -e \"(...
I know it's pretty long but the error pops up just about at the end of the heap of output above.
