Win7 + Lubuntu 16.04 (via USB Memory stick) did not finish installing and when rebooted: boots only into Ubuntu. As expected, Lubuntu was installed in the second HDD partition: Windows partition shrunk to 40GB and was unformatted for Lubuntu.
This is the screenshot of where installation froze: enter image description here
Is it possible to command the USB install to continue setting up and finish the dual boot mecahnism?
gatorback
  • 6,523
First you must update the initramfs. Then you need to reinstall grub and update it. Here are the steps.
  1. Once you have logged in Lubuntu, open a terminal using Ctrl + Alt + T.
  2. First log into root shell using sudo -s.
  3. Run update-initramfs -u and hit Enter
  4. After the execution of the command has completed run grub-install /dev/sdX where sdX is your HDD. If the OS is installed on internal HDD, then replace sdX by sda. The command would then look like grub-install /dev/sda.
  5. After the grub has installed, run update-grub.
  6. After the command has finished executing log out of the root shell by pressing Ctrl + D.
  7. Now close the terminal and reboot the system.
You will now have the option to boot into either OSes.
Severus Tux
  • 10,126
Ceda EI
  • 2,070
