The output which I get while installing ClipGrab using ppa is :-
Reading package lists... Done
W: The repository 'http://ppa.launchpad.net/clipgrab-team/ppa/ubuntu yakkety Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch http://ppa.launchpad.net/clipgrab-team/ppa/ubuntu/dists/yakkety/main/binary-amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
jaggu@jaggu-Lenovo-G50-80:~$ sudo apt-get install clipgrab
Building dependency tree
clipgrab : Depends: libavcodec-extra-53 (>= 4:0.8.6) but it is not installable
How do I solve this problem and install ClipGrab ?
