I've installed nvidia-367 on my system (Ubuntu 16.04). For a reason i don't know, restarting the lightdm service leads to a modification of /etc/alternatives/x86_64-linux-gnu_gl_conf.
I run manually:
root@tron:~# update-alternatives --config x86_64-linux-gnu_gl_conf There are 3 choices for the alternative x86_64-linux-gnu_gl_conf (providing /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf). Selection Path Priority Status ------------------------------------------------------------ 0 /usr/lib/nvidia-367/ld.so.conf 8604 auto mode 1 /usr/lib/nvidia-367-prime/ld.so.conf 8603 manual mode 2 /usr/lib/nvidia-367/ld.so.conf 8604 manual mode * 3 /usr/lib/x86_64-linux-gnu/mesa/ld.so.conf 500 manual mode Press to keep the current choice[*], or type selection number: 0 update-alternatives: using /usr/lib/nvidia-367/ld.so.conf to provide /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) in auto mode
and service lightdm restart ending up with:
There are 3 choices for the alternative x86_64-linux-gnu_gl_conf (providing /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf). Selection Path Priority Status ------------------------------------------------------------ * 0 /usr/lib/nvidia-367/ld.so.conf 8604 auto mode 1 /usr/lib/nvidia-367-prime/ld.so.conf 8603 manual mode 2 /usr/lib/nvidia-367/ld.so.conf 8604 manual mode 3 /usr/lib/x86_64-linux-gnu/mesa/ld.so.conf 500 manual mode Press to keep the current choice[*], or type selection number:
again. That problem is, that with the wrong ld.so.conf the nvidia driver can not be loaded:
/var/log/Xorg.0.log:
[ 1649.307] (II) LoadModule: "nvidia" [ 1649.308] (WW) Warning, couldn't open module nvidia [ 1649.308] (II) UnloadModule: "nvidia" [ 1649.308] (II) Unloading nvidia [ 1649.308] (EE) Failed to load module "nvidia" (module does not exist, 0)
Any ideas what, where and why the restart touches these alternative-settings?
root@tron:~# dpkg -s nvidia-367 | grep 'Version' Version: 367.57-0ubuntu0.16.04.1 root@tron:~# dpkg -s lightdm | grep 'Version' Version: 1.18.3-0ubuntu1
P.S. I tried already to purge nvidia* and reinstalling the driver, without any success.
