I want to convert a ogg file to aac. But I need to transfer all the data of the ogg file (i.e. album, year, cover,...) to the aac file using a shell comand.
Thanks!
pl1nk
  • 6,667
ffmpeg -i input.ogg -strict experimental -acodec aac output.aac
you can find ffmpeg in the official repository.
Micro
  • 2,178
  • 15
Transcoding from one lossy format to another is not ideal. However, if you insist on doing so, this is the best way: install avconv and ubuntu-restricted-extras with
sudo apt-get install avconv ubuntu-restricted-extras
then get neroAacEnc:
wget http://ftp6.nero.com/tools/NeroAACCodec-1.5.1.zip
sudo unzip NeroAACCodec-1.5.1.zip -d /usr/bin linux/*
sudo chmod +x /usr/bin/neroAacDec /usr/bin/neroAacEnc /usr/bin/neroAacTag
NeroAacEnc is superior to avconv's internal AAC encoder, and also much better than libfaac, it consistently scores highly on listening tests; and Nero have released it free for non-commercial use.
To create an M4A (MP4) file, use
avconv -i input.ogg -f wav - | neroAacEnc -if - -ignorelength -q 0.55 -of output.m4a
The -q flag can use any value between 0 and 1, with 1 being highest-quality; according to this, 0.55 averages to a bit rate of 192 kb/s; a lower -q of around 0.4 would probably actually be perfectly suitable for most music listening. Experiment to find out what works best for you.
Unfortunately, this won't keep the metadata; but you can transfer the metadata from input.ogg to output.m4a with a second command:
avconv -i output.m4a -i input.ogg -map 0 -map_metadata 1 -c copy output.m4a
evilsoup
  • 4,625
Use Soundconverter Install soundconverter
And change type of result to AAC under Edit -> Preferences
Achu
  • 21,407
Footbar 2000 can work well to convert music files
AAC
