First download the latest release archive from Font-manager github release page.
Then extract the downloaded archive. If the filename is font-manager-0.7.3.tar.bz2, you can use tar xvf font-manager-0.7.3.tar.bz2 to extract it.
Then install these development packages required to build it
sudo apt-get install build-essential valac libjson-glib-dev libgree-dev libgree-0.8-dev libgucharmap-2-90-dev libsqlite3-dev libgirepository1.0-dev
(Optional) If you use file-browser integration, you also need these packages
- For nautilus -
python-nautilus package
- For thunar -
thunar-python package
(Optional) If you want to be able to use archive support, you need to have file-roller installed (Which comes with Ubuntu by default).
Then use this command to configure while you're in the root of the source
./configure
Optionally, if you want to enable installation from archives, you can use --with-file-roller option to configure command. In that case, you should have file-roller installed.
Also you can enable file-browser integration for nautilus or thunar.
So, for nautilus integreation and archive support, I'd use
./configure --with-file-roller --with-nautilus --with-thunarx
(Yes, it's thunarx, not thunar)
After the configuration is finished, you'll be given a confirmation like this
Font Manager 0.7.3
C compiler: gcc
Vala compiler: /usr/bin/valac
Installation prefix: /usr/local
Archive Support: yes
File Browser Support: yes
Then use make and make install command
make
sudo make install
That should successfully install the font-manager
You can also use sudo checkinstall instead of the last command. That will create a deb file of the application and you can later remove it using this command. Also you can reuse the deb filw without doing all these steps again.
sudo dpkg -r font-manager
(Thanks to muru for noting this)
Update
Check the FontManager author's [answer][auth_ans] for easier method to build a deb package.
