I am a Ubuntu novice. I've set up ssmtp.
If I run
echo "mail test" | sudo ssmtp -vvv xxxxxxxx@domainname.com
it works. Without sudo it doesn't. It gives Authorization failed 535 Incorrect Authentication
So what difference is sudo making ?
If I can resolve this it will help with a bigger problem of why I can't get a shell script to work - it comes up with the same error.
testscript
ssmtp.conf :-
root=xxxxxxxx@domainname.com
mailhub=auth.smtp.vvvvvvv.co.uk
UseTLS=YES
FromLineOverride=YES
UseSTARTTLS=YES
AuthUser=xxxxxxxx@domainname.com
AuthPass=pppppppp
rewriteDomain=domainname.com
AuthMethod=LOGIN
TLS_CA_File=/home/username/cert.pem
testscript shell script
#!/bin/sh
TODAY=$(date)
echo "Test script running $TODAY" >> /home/username/Documents/testfile.log
if ssmtp xxxxxxxx@domainname.com < testscript.txt
then
echo "Test script Complete" >> /home/username/Documents/testfile.log
else
echo "Test script Failed" >> /home/username/Documents/testfile.log
echo "Test script ended" >> /home/username/Documents/testfile.log
testscript.txt
To:xxxxxxxx@domainname.com
Subject:Mail Test
MIME-Version:1.0
Content-Type:text/plain
Auto email test
