I have a small BananaPi (similar to RaspberryPi) running Ubuntu 14.04 LTS and I would like to use it as an FTP server inside my Network. When trying to connect to the server via port 21 using filezilla on the BananaPi, I am getting the massage
Status: Connecting to 127.0.0.1:21...
Status: Connection attempt failed with "ECONNREFUSED - Connection refused by server".
It's the same massage which I get when the server is not even running. In order to set it up I updated and upgraded everything and did the following.
sudo apt-get install proftpd-basic
and selected standalone.
sudo nano /etc/proftpd/proftpd.conf
and changed IPv6 to "off" and the ServerName to "BananaPi".
sudo nano /etc/proftpd/conf.d/proftp-custom.conf
where I inserted
# Ftp user doesn't need a valid shell
<Global>
    RequireValidShell off
</Global>
# Default directory is ftpusers home
    DefaultRoot ~ ftpuser
# Limit login to the ftpuser group
<Limit LOGIN>
    DenyGroup !ftpuser
</Limit>
And last I created the user ftpuser
sudo adduser ftpuser --shell /bin/false --home /var/www/upload
and restarted the server via
sudo service proftpd restart
I uninstalled and reinstalled it several times now without success. What am I doing wrong? How to set it up correctly?
Rob
  • 113
  1. Open FileZilla
  2. Click on Edit from the top menu, then click on Network Configuration Manager. If this is your first time configuring FileZilla's network settings you will be at the Firewall and route configuration wizard.
  3. Select Passive (recommended) and Allow fallback to other transfer mode on failire and click Next.
  4. On the Configure passive mode page select Use the server's external IP address instead and click Next.
  5. Select the Get external IP address from the following URL option, then you can leave the default of http://ip.filezilla-project.org/ip.php
  6. Finally on the Configuration test page, click on Test. If you don't receive any errors than you should be good to go.
