I am using Dell inspiron 3558, after opening the laptop, when I put password in the login screen the same screen appears after two or three seconds. Please tell me what should I do.
Asked
Active
Viewed 160 times
In terminal, type (use the correct username):
cd /home/your_username
ls -l .ICEauthority # (that's a lower case L)
ls -l .Xauthority # (that's a lower case L)
If either ls command returns one of these (where it shows root, instead of your username):
-rw------- 1 root root 242476 Nov 6 12:48 .ICEauthority
-rw------- 1 root root 58 Nov 6 12:48 .Xauthority
Then type (changing your_username to the correct username):
sudo chown your_username:your_username .ICEauthority
and/or
sudo chown your_username:your_username .Xauthority
-1
I had the same issue before. It may be the same case as described in question What represent .Xauthority file?.
Try:
sudo chown your_username .Xauthority
And then try to log in again.
