Installed AMD graphics driver form here. But after reboot, I am unable to login. It keeps comming back to login screen when I type password and hit enter. I can't even login to guest user.
I have tried every thing form this solution but nothing worked for me. I have tried this
chown username:username .Xauthority
sudo chmod a+wt /tmp
dpkg-reconfigure lightdm
sudo service lightdm restart
File also .profile seems fine.
I am using Ubuntu 16.04 LTS, Linux Kernel version 4.xx
Please suggest what to do as I can't get my work done without Ubuntu.
Thanks in advance.
Rahul
  • 1,683
Your GPU is not supported by the amdgpu driver. You should uninstall the driver you installed from AMD.
You need to either use the open source radeon driver included with Ubuntu, or downgrade to Ubuntu 14.04 (no newer than the 14.04.4 point release) and use the fglrx proprietary driver if you need to use it rather than the open source radeon driver.
dobey
  • 41,650
You will have to remove the drivers that you have installed since they are not compatible. In the tty screen Ctrl+Alt+F3 login and uninstall the default graphics on your device:
amdgpu-pro-uninstall
reboot your system and use the open source radeon driver for a temporary fix.
follow this for a permanent fix: https://support.amd.com/en-us/kb-articles/Pages/AMDGPU-PRO-Install.aspx
if the problem still persists, your graphic card might be damaged.
