DP-1 connected primary 1440x900+1920+0 (normal left inverted right x axis y axis) 160mm x 90mm
1440x900 59.89*+
1920x1080 60.05 60.00 50.04
1280x720 60.00 59.94 50.00
1024x768 60.00
800x600 60.32
720x576 50.00
720x480 59.94
640x480 59.94
This is the output I get from xrandr -q
$ lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1c82 (rev a1)
All of the resolutions work (are bad looking though), but the only one that doesn't work (the one I want) does not. All I get is No signal from my monitor when I do this:
xrandr --output DP-1 --mode 1440x900
Additional info:
$ dpkg -l | grep nvidia
ii nvidia-370 370.28-0ubuntu0~gpu16.04.2 amd64 NVIDIA binary driver - version 370.28
ii nvidia-opencl-icd-370 370.28-0ubuntu0~gpu16.04.2 amd64 NVIDIA OpenCL ICD
ii nvidia-prime 0.8.2 amd64 Tools to enable NVIDIA's Prime
ii nvidia-settings 370.28-0ubuntu0~gpu16.04.1 amd64 Tool for configuring the NVIDIA graphics driver
Model: Samsung LE19R86BD
$ cvt 1440 900
# 1440x900 59.89 Hz (CVT 1.30MA) hsync: 55.93 kHz; pclk: 106.50 MHz
Modeline "1440x900_60.00" 106.50 1440 1528 1672 1904 900 903 909 934 -hsync +vsync
$ xrandr --newmode "1440x900_59.89" 106.50 1440 1528 1672 1904 900 903 909 934 -hsync +vsync
$ xrandr --addmode DP-1 "1440x900_59.89"
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 18 (RRAddOutputMode)
Serial number of failed request: 37
Current serial number in output stream: 38
