I used to run this script in Startup and Session in Xubuntu 14.04 to autostart my java app:
xfce4-terminal -e "bash -c \"cd /home/restaurant/Documents/dist/ && java -jar POSv2.jar; exec bash\""
but running the same script in 16.04 causes MySQL Exceptions; I assume these exceptions were thrown because MySql wasn't loaded yet when the script ran. Therefore my question to you how can I make sure the script only get called once MySQl has been loaded successfully?
Chiggiddi
  • 345
Create a script that start every boot that checking every 2 seconds if MySql process is running, if so execute your command.
Lets create the script called filename.sh with this content:
#!/bin/bash
APP="gedit"
while true; do
    PID=`pidof $APP`
    if [ ! -z $PID ]; then
        # We found the process running on the system.
        java -jar "/home/restaurant/Documents/dist/POSv2.jar"
        exit 0
    fi
    sleep 2
done
make it executable:
chmod +x filename.sh
Just change APP="gedit" to the process name instead of gedit.
Make it running at the start up: How do I run a script at start up?.
Benny
  • 5,100
