This question has been extensively discussed under the 'Hauppauge winTv SoloHD unclaimed' 1 question on askubuntu.
My set up is similar.
andrew@xps15:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.1 LTS
Release:    16.04
Codename:   xenial
andrew@xps15:~$ uname -a
Linux xps15 4.4.0-45-generic #66-Ubuntu SMP Wed Oct 19 14:12:37 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
me-tv using Hauppauge WinTV-soloHD usb stick
There are no DVB devices available
andrew@xps15:~$ lsusb
              *-usb:0 UNCLAIMED
                   description: Generic USB device
                   product: soloHD
                   vendor: HCW
                   physical id: 1
                   bus info: usb@1:1
                   version: 1.00
                   serial: 0011529330
                   capabilities: usb-2.00
                   configuration: maxpower=500mA speed=480Mbit/s
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f3:21d5 Elan Microelectronics Corp.
Bus 001 Device 002: ID 0a5c:6410 Broadcom Corp.
Bus 001 Device 004: ID 1bcf:2b95 Sunplus Innovation Technology Inc.
Bus 001 Device 005: ID 2040:0264 Hauppauge
andrew@xps15:~$ dmesg
[ 3023.784687] usb 1-1: new high-speed USB device number 5 using xhci_hcd
[ 3023.913568] usb 1-1: New USB device found, idVendor=2040, idProduct=0264
[ 3023.913570] usb 1-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 3023.913572] usb 1-1: Product: soloHD
[ 3023.913573] usb 1-1: Manufacturer: HCW
[ 3023.913574] usb 1-1: SerialNumber: 0011529330
At this point the answer to the question on askubuntu begins to become very complicated in my opinion. I have the required drivers in /lib/firmware but I have not followed the 'build and make v4l-dvb' thread; its just a bit too much for me - sorry. So my question is: Is there another way to solve my problem? Thanks Andrew
heynnema
  • 73,649
Andrew
  • 31
You can build a separate driver for your hardware like shown here: How (recipe) to build only one kernel module?. No need to build all modules for dvb.
kukulo
  • 2,045
  • 22
