I have a computer that dual boots Linux Mint, and Ubuntu, I am wondering what the best way would be to remove Linux Mint, then recovering the hard drive space that is resides in so that Ubuntu will be able to access it.
Asked
Active
Viewed 6,332 times
Here are steps to claim space from Mint partition.
- Login to Ubuntu
- Start gparted:
sudo gparted. If not available, then install it. Find the Mint partition and format it
Or delete it and create a new partition.
If Mint has modified (taken control of) your boot loader, then :
- Boot from live USB/CD for Ubuntu
- I use the same version. I have no idea how different versions of Ubuntu would work especially 32/64 bit differentiation.
- Open Terminal.
- If you don't know the drive where Ubuntu is installed, use
sudo fdisk -l, which will list partitions. Note down the one with root. Boot will be indicated by a star (*). Assuming your root (/) partition shows /dev/sdaX, where X is a number. Execute:
sudo mount /dev/sdaX /mnt sudo mount --bind /dev /mnt/dev sudo mount --bind /proc /mnt/proc sudo chroot /mntAssuming you have only one HDD and it is sda, execute:
grub-install /dev/sda # Note there is no X hereOnce it is installed unmount all
sudo umount /mnt/dev sudo umount /mnt/proc sudo umount /mnt
Remove USB so you can boot from HDD, then reboot.
wjandrea
- 14,504
wisemonkey
- 3,483
