13
I am using play on linx and I want to to install Starcraft with it but it fails every time I try to. I install it successfully but then when I run battle.net it either doesn't open or crashes instantly.I tried different Wine versions same crash every time.
I am running Ubuntu 16.04 with i7 4790k and a GTX 980
tomkis
  • 425
PlayOnLinux does a terrible job with Starcraft II at the time of this writing. If your end goal is playing Starcraft II on Linux, here's what worked for me, on Ubuntu 17.04
  1. Remove PlayOnLinux entirely.
    sudo apt-get remove playonlinux
  2. Tear out the wine that ships with the OS.
    sudo apt-get remove wine
    sudo apt autoremove
  3. Enable 32 bit architecture
    sudo dpkg --add-architecture i386
  4. Add the repo for wine staging.
    wget -nc https://dl.winehq.org/wine-builds/winehq.key
    sudo apt-key add winehq.key
    sudo apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ ubuntu_version main'
Where 'ubuntu_version' is version like bionic or eoan etc.
  1. Update and install
    sudo apt-get update
    sudo apt-get install winehq-staging
  2. Grab battle.net installer
    wget -O Battle.net-Setup.exe https://www.battle.net/download/getInstallerForGame?os=win&locale=enUS&version=LIVE&gameProgram=BATTLENET_APP
  3. Configure wine by running winecfg and then adjust settings according to the screenshot below. Change out the resolution with your native resolution.
    winecfg
    Wine Configuration Screenshot
  4. Run it with wine
    wine Battle.net-Setup.exe
  5. From there you can pretty much kick off any Blizzard game such as Starcraft II, Diablo 3, or Heros of the Storm on Ubuntu but I've only tested this with Starcraft II.
Furthermore, I had to jump through some extra hoops to get my gaming laptop here to actually use the better of the two graphics card it has inside it. If you're in this boat too, you'll need to keep reading to get Starcraft II just right.
  • Launch "System Settings"
  • Open "Software and Drivers"
  • Access the tab, "Additional Drivers"
  • Switch to the latest binary drivers from the vendor. (Sorry Open Source community - I like Starcraft)
    Binary Drivers selected
  • Then tell Linux to always use your beefy card
    nvidia-settings
  • And set the Prime Profile to NVIDIA
--- This gets you running, but not stable. If I was playing in game more than a couple minutes I got an unhelpful blizzard error. So did some additional changes that have stabilized me.
    sudo apt-get install winetricks winbind
    winetricks corefonts vcrun2005 vcrun2008 vcrun2015
    cd "/home/rakaim/.wine/drive_c/Program Files (x86)/Blizzard App/Battle.net.8394"
    mv "Battle.net Helper.exe" "Battle.net Helper.exe.old"
Installed winetricks and some supporting software. Then I had to rename the Battle.net Helper.exe to old.
Edit: I noticed that this directory "Battle.net.8394" changes its numbers on each Battle.net update. Take care to make the changes you need in the latest installed version.
Edit: New errors suggested that I needed to install winbind. It appears to have helped.
Edit: Upgraded to Ubuntu 17.04
David
  • 3,487
Kurt
  • 438
You need to do advance set up (custom) and install some libs separately, when installing with POL. I am playing SC2 on Ubuntu 16.04. It is still crashing sometimes unfortunately. AFAIR, I more or less followed this https://www.youtube.com/watch?v=jv8s0_5YvLg
These are the native libs I have configured for SC2 (Configure -> Wine -> Configure Wine):
Wine native overrides
Tom
  • 119
