I'm using ubuntu 16.04 desktop and facing below error while i do apt-get operation :
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
10 not fully installed or removed.
Need to get 0 B/224 kB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 120416 files and directories currently installed.)
Preparing to unpack .../python2.7_2.7.12-1~16.04_amd64.deb ...
Unpacking python2.7 (2.7.12-1~16.04) over (2.7.12-1~16.04) ...
Processing triggers for mime-support (3.59ubuntu1) ...
Setting up python3 (3.5.1-3) ...
running python rtupdate hooks for python3.5...
dpkg-query: package 'hplip-data' is not installed
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
Traceback (most recent call last):
  File "/usr/bin/py3clean", line 210, in <module>
    main()
  File "/usr/bin/py3clean", line 196, in main
    pfiles = set(dpf.from_package(options.package))
  File "/usr/share/python3/debpython/files.py", line 53, in from_package
    raise Exception("cannot get content of %s" % package_name)
Exception: cannot get content of hplip-data
error running python rtupdate hook hplip-data
dpkg-query: package 'ibus-table' is not installed
    main()
Exception: cannot get content of ibus-table
error running python rtupdate hook ibus-table
dpkg-query: package 'ibus' is not installed
    main()
dpkg-query: package 'onboard' is not installed
    main()
Exception: cannot get content of onboard
error running python rtupdate hook onboard
dpkg-query: package 'python3-uno' is not installed
    main()
Exception: cannot get content of python3-uno
error running python rtupdate hook python3-uno
dpkg-query: package 'rhythmbox-plugins' is not installed
    main()
Exception: cannot get content of rhythmbox-plugins
error running python rtupdate hook rhythmbox-plugins
dpkg-query: package 'rhythmbox' is not installed
    main()
dpkg-query: package 'totem-plugins' is not installed
    main()
Exception: cannot get content of totem-plugins
error running python rtupdate hook totem-plugins
dpkg-query: package 'ubuntu-drivers-common' is not installed
    main()
Exception: cannot get content of ubuntu-drivers-common
error running python rtupdate hook ubuntu-drivers-common
dpkg: error processing package python3 (--configure):
 subprocess installed post-installation script returned error exit status 4
dpkg: dependency problems prevent configuration of lsb-release:
 lsb-release depends on python3:any (>= 3.4~); however:
  Package python3 is not configured yet.
dpkg: error processing package lsb-release (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of python3-apt:
 python3-apt depends on python3 (<< 3.6); however:
 python3-apt depends on python3 (>= 3.5~); however:
dpkg: error processing package python3-apt (--configure):
dpkg: dependency problems prevent configuration of python-software-properties:
 python-software-properties depends on lsb-release; however:
  Package lsb-release is not configured yet.
dpkg: error processing package python-software-properties (--configure):
dpkg: dependency problems prevent configuration of python3-dev:
 python3-dev depends on python3 (= 3.5.1-3); however:
dpkg: error processing package python3-dev (--configure):
dpkg: dependency problems prevent configuration of python3-pip:
 python3-pip depends on python3:any (>= 3.4~); however:
dpkg: error processing package python3-pip (--configure):
dpkg: dependency problems prevent configuration of python3-pkg-resources:
 python3-pkg-resources depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-pkg-resources (--configure):
dpkg: dependency problems prevent configuration of python3-setuptools:
 python3-setuptools depends on python3-pkg-resources (= 20.7.0-1); however:
  Package python3-pkg-resources is not configured yet.
 python3-setuptools depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-setuptools (--configure):
dpkg: dependency problems prevent configuration of python3-wheel:
 python3-wheel depends on python3:any (>= 3.3.2-2~); however:
dpkg: error processing package python3-wheel (--configure):
dpkg: dependency problems prevent configuration of unattended-upgrades:
 unattended-upgrades depends on python3; however:
 unattended-upgrades depends on python3-apt; however:
  Package python3-apt is not configured yet.
 unattended-upgrades depends on lsb-release; however:
dpkg: error processing package unattended-upgrades (--configure):
Setting up python2.7 (2.7.12-1~16.04) ...
 python3
 lsb-release
 python3-apt
 python3-dev
 python3-pip
 python3-setuptools
 python3-wheel
 unattended-upgrades
Also trying to re-install python but still same error.
Nullpointer
  • 1,191
  • 16
  • 34
