I updated Ubuntu to 16.04 earlier this week and now I can't even get into the system as I get this text screen on boot.
I've gone through a number of solutions on here, as it appears to be an issue with my Nvidia driver, but I still can't get it to work.
I went and changed the grub file to nomodeset and read I should be able to get an option to select my driver on boot, but I don't get anything. This screen of writing is what comes up first before I get the text screen.
When I go into the command prompt to try install or update anything I keep getting these kind of errors.
Run this command
sudo dpkg --configure -a
sudo apt-get install -f
To fix packages problem. then update
sudo apt update
sudo apt upgrade
If it didn't work check this: Answer on: How do I continue configuration if apt-get was interrupted?
Fcmam5
  • 249
Thanks for the reply. I tried the above and it still didn't work. But I managed to get it up and running by simply running the following command.
sudo apt-get install ubuntu-desktop
Why wouldn't this of been installed automatically during the update?
