After new installation of Ubuntu 16.04 freshly installed through apt-get Gnucash not working in normal mode. It will starts only in terminal & and requires sudo "sudo Gnucash". After several attempts of reinstall Gnucash nothing has changed. How to fix it to start without terminal and without sudo root permissions?
Asked
Active
Viewed 533 times
In terminal, type:
$ dpkg -l *gnucash* (that's a lower case L, and *'s are required) Desired=Unknown/Install/Remove/Purge/Hold | Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend |/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad) ||/ Name Version Architecture Description +++-==============-============-============-================================= ii gnucash 1:2.6.14-1~g amd64 personal and small-business finan ii gnucash-common 1:2.6.14-1~g all common files for the financial-ac ii gnucash-docs 2.6.13-2 all Documentation for gnucash, a pers ii python-gnucash 1:2.6.14-1~g amd64 Gnucash interface for Python
If you don't see python-gnucash with ii in front of its name in this list, install it using Synaptic.
Start Synaptic from the dash, click the RELOAD icon, click the SEARCH icon, enter "python-gnucash", in the results pane, mark it for installation, click the APPLY icon.
heynnema
- 73,649
