I have a mounted a partial disk on my Ubuntu VPS.
After a reboot the disk will be unmounted.
I can remount it manually but it keeps unmounting after rebooting the VPS and this stops the cron jobs I use for making backups.
In /etc/fstab I added the line:
https://[mylink].stackstorage.com/remote.php/webdav/ /var/stack davfs user,rw,noauto 0 0
[mylink] = my own stack storage name.
The url is correct. If I open it then it asks for my credentials and gives back an "Ok" status.
I don't use users on my VPS; I do everything as root (not sure if this could be the issue).
I have followed this tutorial to set up my partial disk (sorry it's in Dutch).
Zanna
  • 72,312
try to add _netdev and remove noauto to your /etc/fstab entry.
Example:
https://[mylink].stackstorage.com/remote.php/webdav/ /var/stack davfs user,_netdev,rw 0 0
From the Manual Page:
_netdev
          The filesystem resides on a device that requires network access (used to prevent
          the system from attempting to mount these filesystems until the network has been
          enabled on the system).
noauto - The filesystem will NOT be automatically mounted at startup, or when mount passed -a. You must explicitly mount the filesystem.
More info:
https://help.ubuntu.com/community/Fstab https://wiki.ubuntu.com/MountWindowsSharesPermanently
Benny
  • 5,100
